소개
Use this guide to replace a defective Motherboard.
필요한 것
Insert plastic opening tool under back cover.
Apply pressure on tool while using a downward motion to pop off back cover.
Pry the top cover upward to remove it from the phone.
Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
Insert the pointed end of a spudger into the gap in the round housing frame.
Using spudger to remove vibrator remove from the adhesive.
Insert the spudger under each corner ribbon cable and lift them out of the way.
Insert a plastic pry tool into the gap between motherboard and base of phone
다른 3명이 해당 안내서를 완성하였습니다.
