주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Exhibit II 4G Rear Facing Camera Replacement
필요한 것
  1. Samsung Exhibit II 4G Rear Facing Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Rear Facing Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Rear Facing Camera Replacement, Top Rear Housing Cover: 3 단계, 이미지 1개 중 1개
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Rear Facing Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the top cover.
  5. Samsung Exhibit II 4G Rear Facing Camera Replacement: 5 단계, 이미지 2개 중 1개 Samsung Exhibit II 4G Rear Facing Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Rear Facing Camera Replacement: 6 단계, 이미지 3개 중 1개 Samsung Exhibit II 4G Rear Facing Camera Replacement: 6 단계, 이미지 3개 중 2개 Samsung Exhibit II 4G Rear Facing Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Rear Facing Camera Replacement, Midframe: 7 단계, 이미지 1개 중 1개
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Rear Facing Camera Replacement: 8 단계, 이미지 1개 중 1개
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Rear Facing Camera Replacement: 9 단계, 이미지 1개 중 1개
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Rear Facing Camera Replacement: 10 단계, 이미지 1개 중 1개
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Rear Facing Camera Replacement, Rear Facing Camera: 11 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to disconnect the camera assembly cable.
  12. Samsung Exhibit II 4G Rear Facing Camera Replacement: 12 단계, 이미지 2개 중 1개 Samsung Exhibit II 4G Rear Facing Camera Replacement: 12 단계, 이미지 2개 중 2개
    • Remove camera from square housing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
David R
회원 가입일: 07/20/15
1,152 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 49
전체 시간: 517
