주요 콘텐츠로 건너뛰기
Samsung Exhibit II 4G Top Rear Housing Cover Replacement
필요한 것
  1. Samsung Exhibit II 4G Top Rear Housing Cover Replacement, Battery: 1 단계, 이미지 1/1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: 2 단계, 이미지 1/1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Top Rear Housing Cover Replacement, Top Rear Housing Cover: 3 단계, 이미지 1/1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: 4 단계, 이미지 1/1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: 5 단계, 이미지 1/2 Samsung Exhibit II 4G Top Rear Housing Cover Replacement: 5 단계, 이미지 2/2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: 6 단계, 이미지 1/3 Samsung Exhibit II 4G Top Rear Housing Cover Replacement: 6 단계, 이미지 2/3 Samsung Exhibit II 4G Top Rear Housing Cover Replacement: 6 단계, 이미지 3/3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
David R
회원 가입일: 07/20/15
1,152 평판
안내서 9개 작성하였습니다
Eastern Washington University, Team 1-3, Rowley SU 2015 Eastern Washington University, Team 1-3, Rowley SU 2015 회원
EWU-ROWLEY-SU15S1G3
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 25
전체 시간: 291
