주요 콘텐츠로 건너뛰기
Samsung Fascinate Speaker Replacement
필요한 것
  1. Samsung Fascinate Speaker Replacement, Back Case: 1 단계, 이미지 3개 중 1개 Samsung Fascinate Speaker Replacement, Back Case: 1 단계, 이미지 3개 중 2개 Samsung Fascinate Speaker Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • To remove the back case of the Samsung Galaxy S, you may need a spudger.
    • Identify the slit which is at the bottom edge of the phone.
  2. Samsung Fascinate Speaker Replacement: 2 단계, 이미지 2개 중 1개 Samsung Fascinate Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the edge of the spudger into the slit and use it to pry the back case off of the phone.
  3. Samsung Fascinate Speaker Replacement, Battery: 3 단계, 이미지 2개 중 1개 Samsung Fascinate Speaker Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Insert the spudger into the space between the battery and the phone and pry the battery out as you slide it along the underside the battery.
  4. Samsung Fascinate Speaker Replacement, Speaker: 4 단계, 이미지 3개 중 1개 Samsung Fascinate Speaker Replacement, Speaker: 4 단계, 이미지 3개 중 2개 Samsung Fascinate Speaker Replacement, Speaker: 4 단계, 이미지 3개 중 3개
    • Use the screwdriver to unscrew each of the 6 silver screws holding the main case to the LCD touchscreen.
    • If the screws are stuck, use the spudger to pry them out.
  5. Samsung Fascinate Speaker Replacement: 5 단계, 이미지 3개 중 1개 Samsung Fascinate Speaker Replacement: 5 단계, 이미지 3개 중 2개 Samsung Fascinate Speaker Replacement: 5 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to pry the main case from the LCD touchscreen.
    • Insert the thin edge of the plastic opening tool into the groove between the silver edge and black edge.
    • Run the tool all the way around the edge of the phone until you hear each of the clips detach.
  6. Samsung Fascinate Speaker Replacement: 6 단계, 이미지 3개 중 1개 Samsung Fascinate Speaker Replacement: 6 단계, 이미지 3개 중 2개 Samsung Fascinate Speaker Replacement: 6 단계, 이미지 3개 중 3개
    • Once the clips are detached, separate the main case from the LCD touchscreen.
  7. Samsung Fascinate Speaker Replacement: 7 단계, 이미지 3개 중 1개 Samsung Fascinate Speaker Replacement: 7 단계, 이미지 3개 중 2개 Samsung Fascinate Speaker Replacement: 7 단계, 이미지 3개 중 3개
    • Use the spudger to pry out the grey rubber rectangular component from the main case.
  8. Samsung Fascinate Speaker Replacement: 8 단계, 이미지 3개 중 1개 Samsung Fascinate Speaker Replacement: 8 단계, 이미지 3개 중 2개 Samsung Fascinate Speaker Replacement: 8 단계, 이미지 3개 중 3개
    • Use the spudger to pry along the groove between the speaker and the main case.
    • Once the speaker is unclipped it should pop out easily.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kevin Carlson
회원 가입일: 04/22/11
236 평판
안내서 6개를 작성함
Cal Poly, Team 25-25, Garner Spring 2011 Cal Poly, Team 25-25, Garner Spring 2011 회원
CPSU-GARNER-S11S25G25
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 5,589
