소개
Hello everyone! Today I am going to show you how to replace a battery in the Samsung Keystone 2. It’s very simple if you make sure to follow the directions carefully, so let’s get started!
필요한 것
For a more effortless experience, use an opening tool to remove the back. Simply push the opening tool into the indent in the bottom and work your way around a little so you can pop it off.
Remove the battery by pulling it out, replacing it with a new one, and putting the cover back on.
거의 끝나갑니다!
결론
