주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Samsung GT-E2120 수리는 자사의 서비스 설명서를 사용하세요.
  1. Samsung GT-E2120 Teardown, Samsung GT-E2120 Teardown: 1 단계, 이미지 1개 중 1개
    • Before you begin it's always good to ground yourself to eliminate the risk for shock.
  2. Samsung GT-E2120 Teardown: 2 단계, 이미지 2개 중 1개 Samsung GT-E2120 Teardown: 2 단계, 이미지 2개 중 2개
    • Using your thumb, press down on the back of the device in a downward motion to open the back cover.
    • Remove the battery along with the sim card and Micro-SD card.
    • This phone can take up to a 2GB Micro-SD card and is great for storing music. It even has a FM radio!
  3. Samsung GT-E2120 Teardown: 3 단계, 이미지 2개 중 1개 Samsung GT-E2120 Teardown: 3 단계, 이미지 2개 중 2개
    • Next, using a Philips screwdriver, remove the five screws from the back of the device.
  4. Samsung GT-E2120 Teardown: 4 단계, 이미지 3개 중 1개 Samsung GT-E2120 Teardown: 4 단계, 이미지 3개 중 2개 Samsung GT-E2120 Teardown: 4 단계, 이미지 3개 중 3개
    • For this step a matal spudger is used to release the clips along the bottom, top, and sides of the phone.
    • These clips can be found at the points marked in red.
    • Working from the top down, gently prying at the case the clips are easily dislodged.
  5. Samsung GT-E2120 Teardown: 5 단계, 이미지 2개 중 1개 Samsung GT-E2120 Teardown: 5 단계, 이미지 2개 중 2개
    • When the bottom of the phone is reached it is a bit harder to pull the bottom clips off.
    • This can be made a tad easier by using the pointed end of the spudger to get in and under the case.
    • Once the case is lifted up slightly, you can get enough purchase under the clip and lift it off.
    • Be careful so you dont damage the motherboard!
  6. Samsung GT-E2120 Teardown: 6 단계, 이미지 1개 중 1개
    • This images shows the two halves separated.
    • The camera located in the blue square is a VGA 640X480 resolution color camera.
  7. Samsung GT-E2120 Teardown: 7 단계, 이미지 2개 중 1개 Samsung GT-E2120 Teardown: 7 단계, 이미지 2개 중 2개
    • The microphone is carefully lifted from its bracket, and the motherboard is carefully removed.
  8. Samsung GT-E2120 Teardown: 8 단계, 이미지 1개 중 1개
    • Then the keyboard is simply pushed out.
    • The Phone includes a 65K CSTN color screen with a 128X128 resolution.
작성자
3다른 기여자 명과 함께
Michael C
회원 가입일: 01/09/11
410 평판
안내서 1개를 작성함
OPEN OPEN 회원
Community
85 회원들
안내서 27개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 14,224
