소개
Use this guide to replace the daughterboard containing the charge port and headphone jack.
필요한 것
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
Remove screws from the motherboard antenna cover.
3 Phillips #00, 3mm length.
Use a spudger to disconnect the battery by prying the connector straight up from its socket.
Insert the flat end of a spudger under the interconnect flex connector, and gently pry it straight up.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 2개
a common issue with the A10E is the phone notifying you that you have water damage in the usb type-C port this can be fixed by replacing the daughter board which has a IC which is commonly faulty.
From where can you obtain a new daughterboard?
