주요 콘텐츠로 건너뛰기
Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement
필요한 것
  1. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Prepare the phone for disassembly: 1 단계, 이미지 3개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Prepare the phone for disassembly: 1 단계, 이미지 3개 중 2개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Prepare the phone for disassembly: 1 단계, 이미지 3개 중 3개
    • Let the phone's battery drain below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
    • Unplug all cables and completely power off the phone.
    • Press and hold the power and volume down buttons at the same time to bring up the shutdown menu.
  2. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Heat the right edge: 2 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer may also be used, but be careful not to overheat the phone—the display, internal battery, and plastic back are susceptible to heat damage. The phone should be just too hot to touch comfortably.
  3. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 3 단계, 이미지 1개 중 1개
    • While you're waiting for the adhesive to soften, here is some useful information:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • There is an additional layer of adhesive towards the bottom of the phone. Apart from this area, you should not be deeper than 4 mm from the edge.
  4. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 2개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 3개
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble, apply more heat to further soften the adhesive.
    • Insert an opening pick into the gap.
  5. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Slice the adhesive: 5 단계, 이미지 3개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Slice the adhesive: 5 단계, 이미지 3개 중 2개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Slice the adhesive: 5 단계, 이미지 3개 중 3개
    • Slide the opening pick along the right edge between the back cover and the frame to slice through the adhesive.
    • Leave the opening pick in the bottom right corner to keep the adhesive from resealing.
  6. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 6 단계, 이미지 1개 중 1개
    • Reheat your iOpener and apply it to the bottom of the back cover for two minutes.
  7. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 7 단계, 이미지 3개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 7 단계, 이미지 3개 중 2개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 7 단계, 이미지 3개 중 3개
    • Insert another opening pick in the bottom right corner and slide it along the bottom edge to slice through the adhesive.
    • Leave this opening pick in the bottom left edge to prevent the adhesive from resealing.
  8. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 8 단계, 이미지 1개 중 1개
    • Reheat your iOpener and apply it to the left side of the back cover for two minutes.
  9. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 9 단계, 이미지 3개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 9 단계, 이미지 3개 중 2개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 9 단계, 이미지 3개 중 3개
    • Insert another opening pick in the bottom left corner and slide it along the left edge to slice through the adhesive.
    • Leave this opening pick in the top left corner to prevent the adhesive from resealing.
    • Only insert the pick up to 4 mm deep to avoid damaging the rear cameras or flash.
  10. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 10 단계, 이미지 1개 중 1개
    • Reheat your iOpener and apply it to the top of the back cover for two minutes.
  11. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 11 단계, 이미지 2개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 11 단계, 이미지 2개 중 2개
    • Insert another opening pick in the top left corner at the same depth and slide it along the top edge to slice through the adhesive.
    • Leave this opening pick in the top right corner to prevent the adhesive from resealing.
  12. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Unfasten the camera clips: 12 단계, 이미지 3개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Unfasten the camera clips: 12 단계, 이미지 3개 중 2개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Unfasten the camera clips: 12 단계, 이미지 3개 중 3개
    • Insert an opening pick along the top edge of the phone and twist it gently to unfasten the camera clips.
    • Slide the opening pick around the edge of the camera modules to unfasten the remaining camera clips.
    • Only insert the pick up to 4 mm to avoid damaging the rear cameras or flash.
  13. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Slice remaining adhesive: 13 단계, 이미지 3개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Slice remaining adhesive: 13 단계, 이미지 3개 중 2개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Slice remaining adhesive: 13 단계, 이미지 3개 중 3개
    • Once the adhesive around the edges is loose, insert an opening pick deeper into the bottom edge from the bottom left corner.
    • Slide the pick deeper into the phone across the bottom edge, slicing the remaining adhesive.
  14. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the back cover: 14 단계, 이미지 3개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the back cover: 14 단계, 이미지 3개 중 2개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the back cover: 14 단계, 이미지 3개 중 3개
    • Lift and remove the back cover.
    • During reassembly:
    • This is a good point to power on the phone and test all functions before sealing it up. Be sure to power the phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  15. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the SIM tray: 15 단계, 이미지 3개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the SIM tray: 15 단계, 이미지 3개 중 2개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the SIM tray: 15 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located towards the top of the phone on the left edge.
    • Press in firmly to eject the tray and remove it.
  16. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the frame screws: 16 단계, 이미지 1개 중 1개
    • Remove the fifteen 4 mm-long screws connecting the frame to the chassis.
  17. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Disconnect the fingerprint button: 17 단계, 이미지 2개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Disconnect the fingerprint button: 17 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the fingerprint button press connector from the motherboard.
  18. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Unfasten the frame clips: 18 단계, 이미지 3개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Unfasten the frame clips: 18 단계, 이미지 3개 중 2개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Unfasten the frame clips: 18 단계, 이미지 3개 중 3개
    • Flip the phone over so the screen is facing up.
    • Insert an opening pick between the screen and the SIM card tray cutout to form a gap between the frame and the phone.
    • Slide the opening pick down the left edge of the device to unfasten the frame clips.
  19. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 19 단계, 이미지 3개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 19 단계, 이미지 3개 중 2개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 19 단계, 이미지 3개 중 3개
    • Continue sliding the opening pick around the perimeter of the phone until all of the clips are unfastened.
    • If the opening pick comes out of the phone, re-insert it at the last unfastened corner.
  20. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the frame: 20 단계, 이미지 2개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the frame: 20 단계, 이미지 2개 중 2개
    • Pull the frame straight off of the phone.
  21. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Disconnect the battery: 21 단계, 이미지 2개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Disconnect the battery: 21 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to lift up and disconnect the battery press connector from the motherboard.
  22. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Disconnect the interconnect cable: 22 단계, 이미지 2개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Disconnect the interconnect cable: 22 단계, 이미지 2개 중 2개
    • The connector labeled "OCTA" is not connected to the board but rather the display cable connector. Make sure you disconnect the connectors from each other.
    • Insert the flat end of a spudger under the overhang of the top "OCTA" cable connector.
    • Pry up the top connector away from the bottom one until they're disconnected.
  23. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 23 단계, 이미지 2개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 23 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up the "SUB" connector from the daughterboard and disconnect it.
  24. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 24 단계, 이미지 2개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement: 24 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up the "MAIN" connector from the motherboard and disconnect it.
  25. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the interconnect cable: 25 단계, 이미지 2개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the interconnect cable: 25 단계, 이미지 2개 중 2개
    • Pick up the interconnect cable and remove it from the phone.
  26. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Disconnect the coaxial antenna connectors: 26 단계, 이미지 3개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Disconnect the coaxial antenna connectors: 26 단계, 이미지 3개 중 2개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Disconnect the coaxial antenna connectors: 26 단계, 이미지 3개 중 3개
    • Insert one arm of angled tweezers under the metal neck of the red antenna coaxial connector on the daughterboard and lift straight up to disconnect it.
    • Be gentle when removing the red antenna cable from its holder to avoid damaging the cable.
    • Repeat for the other connector.
    • During reassembly, use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
  27. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Detach the display cable connector: 27 단계, 이미지 2개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Detach the display cable connector: 27 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $2.99
    • Insert the flat end of a spudger underneath the flex ribbon connector and pry it off of the board.
    • During reassembly, you may need to replace the adhesive holding this connector to the daughterboard. If your new daughterboard does not include it, use thin, double-sided adhesive instead.
  28. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the daughterboard screw: 28 단계, 이미지 2개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the daughterboard screw: 28 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the 3 mm‑long screw securing the daughterboard to the phone.
  29. Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the daughterboard: 29 단계, 이미지 2개 중 1개 Samsung Galaxy A15 USB-C Charging Port and Daughterboard Replacement, Remove the daughterboard: 29 단계, 이미지 2개 중 2개
    • Grab the daughterboard by its edges and pull it up and out of the phone.
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
다른 8명이 해당 안내서를 완성하였습니다.
Nick Schultz
회원 가입일: 03/24/24
36,927 평판
안내서 224개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
6가이드 댓글
Could you post another picture from the daughterboard, showing the other side of it? I need to see if that usb-c port has just one or two rows of pads.
Rodolfo Ferreira - 답글
Here you go! Let me know if you need additional photos.
Nick Schultz -
Step 18 - You should mention that you start working here on the FRONT of the case. I worked for 10 minutes on he BACK side trying to get the frame clips to release, They don't! I did finally get it all.
Rick Cox - 답글
Thanks for the feedback, I've edited the step to clarify. Glad you were able to repair your device!
Nick Schultz -
Same thing happened to me on step 18. I was on the back side not the front I used my fingernail to pry it off. It pays to be a classical guitarist with long nails. I was about to give up until I viewed a YouTube tutorial. You are driving customers away from the pros. I bought the part and they wanted to charge me $60 just for labor to install it. Stupid Assurant insurance protection wouldn't cover the USB port so I decided to do it myself. Now who's gonna give me $60?
Jorge Luis Valenciano - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 88
지난 30일: 337
전체 시간: 4,669
