주요 콘텐츠로 건너뛰기
Samsung Galaxy A3 (2017) Motherboard Cover including NFC Antenna and Loudspeaker Replacement
필요한 것
  1. Samsung Galaxy A3 (2017) Motherboard Cover including NFC Antenna and Loudspeaker Replacement, Back cover replacement: 1 단계, 이미지 1/1
    • Power off your phone before beginning disassembly.
    • Use an iOpener to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Samsung Galaxy A3 (2017) is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A3 (2017) Motherboard Cover including NFC Antenna and Loudspeaker Replacement: 2 단계, 이미지 1/3 Samsung Galaxy A3 (2017) Motherboard Cover including NFC Antenna and Loudspeaker Replacement: 2 단계, 이미지 2/3 Samsung Galaxy A3 (2017) Motherboard Cover including NFC Antenna and Loudspeaker Replacement: 2 단계, 이미지 3/3
    • Use a small suction handle to create a gap at the bottom end of the Galaxy A3.
    • Insert an opening pick and slide the tip to the bottom left corner to cut the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
    • Insert a new opening pick and start to cut the adhesive towards the bottom left side of the phone.
  3. Samsung Galaxy A3 (2017) Motherboard Cover including NFC Antenna and Loudspeaker Replacement: 3 단계, 이미지 1/3 Samsung Galaxy A3 (2017) Motherboard Cover including NFC Antenna and Loudspeaker Replacement: 3 단계, 이미지 2/3 Samsung Galaxy A3 (2017) Motherboard Cover including NFC Antenna and Loudspeaker Replacement: 3 단계, 이미지 3/3
    • Use an opening pick to cut the adhesive on all sides of the phone. Leave one opening pick in every corner to prevent the adhesive from resealing.
    • Reuse an iOpener if the adhesive becomes hard to cut. During the removal process the back cover is under tension all the time and is likely to break if the adhesive isn't loose enough.
    • Insert an opening pick on the right side of the phone after you cut the adhesive on all sides. Flip it sideways until you can get a good grip on the back cover.
  4. Samsung Galaxy A3 (2017) Motherboard Cover including NFC Antenna and Loudspeaker Replacement: 4 단계, 이미지 1/1
    • Remove the back cover from the phone.
    • Before applying new adhesive remove any remaining adhesive from the back cover and the frame and clean the areas with isopropyl alcohol and a lint-free cloth.
  5. Samsung Galaxy A3 (2017) Motherboard Cover including NFC Antenna and Loudspeaker Replacement, Motherboard cover including NFC antenna and loudspeaker replacement: 5 단계, 이미지 1/1
    • Remove the five Phillips #00 screws that hold the motherboard covers in their place.
  6. Samsung Galaxy A3 (2017) Motherboard Cover including NFC Antenna and Loudspeaker Replacement: 6 단계, 이미지 1/1
    • Use a pair of tweezers to remove the upper part of the motherboard cover.
    • The cover is secured by small plastic clamps. Don't break them during the removal procedure.
  7. Samsung Galaxy A3 (2017) Motherboard Cover including NFC Antenna and Loudspeaker Replacement: 7 단계, 이미지 1/1
    • Use a pair of tweezers to lift up the motherboard cover including the loudspeaker and the NFC antenna and remove it.
결론
To reassemble your device, follow these instructions in reverse order. When reassembling apply new adhesive where it's necessary.
다른 5명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
165,692 평판
안내서 661개 작성하였습니다
iFixit iFixit 회원
Community
138 회원들
안내서 17,042개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 45
전체 시간: 2,806
