주요 콘텐츠로 건너뛰기
Samsung Galaxy A3 Display / LCD Replacement
필요한 것
  1. Samsung Galaxy A3 Display / LCD Replacement, Display / LCD: 1 단계, 이미지 1/1
    • Heat up the edges of the display with a heat gun or iPad opener.
  2. Samsung Galaxy A3 Display / LCD Replacement: 2 단계, 이미지 1/2 Samsung Galaxy A3 Display / LCD Replacement: 2 단계, 이미지 2/2
    • Using a pick or slim plastic tool, work around the edge of the frame to loosen the glass.
    • Watch out for the ear speaker, camera and light sensor on the top of the phone.
    • When working the glass free around the bottom of the phone, slide the tool out to avoid damaging the left and right home buttons (as shown in picture 2).
    • NOTE: The LCD is also glued to the frame and will most likely break when removing the display.
  3. Samsung Galaxy A3 Display / LCD Replacement: 3 단계, 이미지 1/2 Samsung Galaxy A3 Display / LCD Replacement: 3 단계, 이미지 2/2
    • Once the display has been disconnected, lift the top of the display away from the phone to expose the home buttons (Shown in green)
    • Pry the contacts gently off the underside of the glass and push them back into the recesses on the phone (shown in yellow).
  4. Samsung Galaxy A3 Display / LCD Replacement: 4 단계, 이미지 1/1
    • Connect the new display and seat it in the phone, without removing the plastic for the adhesive.
    • Turn the phone on to make sure the display and home buttons work. If you glue the display without testing it first, it's a pain to take it off again once it has been glued and runs the risk of the display breaking.
    • If the display works, remove the plastic covering the adhesive and seat the display in the phone. Push gently around the edges to ensure a good seal
결론
To reassemble your device, follow these instructions in reverse order. Do not attempt this while driving or lovemaking :)
다른 41명이 해당 안내서를 완성하였습니다.
Harvey
회원 가입일: 02/15/16
5,193 평판
안내서 10개 작성하였습니다
댓글 6개
The lcd on my phone was physically glued to the inside of the phone so it broke when trying to remove it (which wasn't a problem as it was dead anyway) but this needs to be mentioned as it isn't!
Clems - 답글
It’s been mentioned in step 2
Siamak -
nice man really cool staff
Shelton Chiuswa - 답글
Is the concept the same with newer models of the Samsung Galaxy A3?
Frederik Novak Jansen - 답글
The 2016 Model is different, so I would look for the model specific repair information:
Samsung A3 2016 Model - A310F Display / LCD Replacement
This is a guide I wrote for the 2016 model...Hope it helps!
Harvey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 12
30일 전: 33
전체 시간: 46,192
