주요 콘텐츠로 건너뛰기
Samsung Galaxy A3 Display Replacement
필요한 것
  1. Samsung Galaxy A3 Display Replacement, Display: 1 단계, 이미지 1/3 Samsung Galaxy A3 Display Replacement, Display: 1 단계, 이미지 2/3 Samsung Galaxy A3 Display Replacement, Display: 1 단계, 이미지 3/3
    • Switch off your phone.
    • If your screen is cracked you want to cover the front panel with tape to protect yourself from glass shards and get a better grip to lift it.
    • Use an iOpener to soften the glue on the edge of the display. Concentrate on the sides first and then on the bottom part.
    • With an iSclack or a suction handle you can lift the display a little bit to get in the gap with an opening pick.
    • In the beginning just insert the very tip of the opening pick and slide along the side to loosen the glue. Leave the top and bottom alone for now.
  2. Samsung Galaxy A3 Display Replacement: 2 단계, 이미지 1/3 Samsung Galaxy A3 Display Replacement: 2 단계, 이미지 2/3 Samsung Galaxy A3 Display Replacement: 2 단계, 이미지 3/3
    • When the glue ist loosened enough on the side you can lift the display a little bit more to get underneath the display with an opening pick.
    • Take a second opening pick and work your way just around the bottom edge.
    • Be careful where the two touch buttons at the bottom are (see next step for orientation). Take your time and be patient.
    • Repeat the last step and this one on the other side.
  3. Samsung Galaxy A3 Display Replacement: 3 단계, 이미지 1/3 Samsung Galaxy A3 Display Replacement: 3 단계, 이미지 2/3 Samsung Galaxy A3 Display Replacement: 3 단계, 이미지 3/3
    • Grab the iOpener once again to heat up the bottom and top part to further soften the glue.
    • Now you will be able to move the picks at the bottom closer to the home button and eventually open the display towards the top.
    • Don't open the display all the way. It is still connected to the motherboard. Also the gold foil behind the display might come off and remain glued to the midframe. You can re-attach it later.
    • If your display is still working take care to not rip the front panel off of the display. You also want to leave the top part alone to not risk cutting any flex cables.
  4. Samsung Galaxy A3 Display Replacement: 4 단계, 이미지 1/3 Samsung Galaxy A3 Display Replacement: 4 단계, 이미지 2/3 Samsung Galaxy A3 Display Replacement: 4 단계, 이미지 3/3
    • In the top right corner you can find the connector of the display. Use a spudger to disconnect it.
    • Now you can remove the display.
결론
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
다른 43명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
117,598 평판
안내서 188개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 한 개
Hi, thank you for this guide. I want to replace my battery, but I don’t see how to re-seal the screen in the end? Do we need to heat the screen the same way we did? Or do we need to use new adhesive?
Quentin Roques - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 27
30일 전: 62
전체 시간: 15,079
