주요 콘텐츠로 건너뛰기
Samsung Galaxy A40 Charging Board Replacement
필요한 것
동영상 개요
  1. Samsung Galaxy A40 Charging Board Replacement, Charging Dock / Charging Board: 1 단계, 이미지 1/2 Samsung Galaxy A40 Charging Board Replacement, Charging Dock / Charging Board: 1 단계, 이미지 2/2
    • The spare part: Daughter board with Charging port, Microphone, Main flex cable connector, display connector, 3G, 4G antennas
  2. Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: 2 단계, 이미지 1/3 Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: 2 단계, 이미지 2/3 Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: 2 단계, 이미지 3/3
    • Turn off the device by pressing and holding the small button on the right side. After a few seconds, press the Power Off button and wait until the device has completely shut off
    • To soften the adhesive, use a heat gun or heating pad to warm up the device.
    • Use a Spudger (Or playing card) , Suction Cup, and Isopropyl alcohol to separate the back cover.
  3. Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: 3 단계, 이미지 1/3 Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: 3 단계, 이미지 2/3 Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: 3 단계, 이미지 3/3
    • Be very careful when removing the ribbons in this step! Damaging the ribbons may cause parts of your phone to stop working
    • Remove the SIM tray.
    • Remove the plastic cover that covers the Fingerprint flex connector.
    • Disconnect the Fingerprint Sensor.
  4. Samsung Galaxy A40 Charging Board Replacement: 4 단계, 이미지 1/3 Samsung Galaxy A40 Charging Board Replacement: 4 단계, 이미지 2/3 Samsung Galaxy A40 Charging Board Replacement: 4 단계, 이미지 3/3
    • Remove the 13 screws
    • Remove the back cover
  5. Samsung Galaxy A40 Charging Board Replacement: 5 단계, 이미지 1/2 Samsung Galaxy A40 Charging Board Replacement: 5 단계, 이미지 2/2
    • Disconnect the Main flex cable, Display flex cable and the Coaxial antenna cable.
    • Remove the black screw securing the charging board.
  6. Samsung Galaxy A40 Charging Board Replacement: 6 단계, 이미지 1/3 Samsung Galaxy A40 Charging Board Replacement: 6 단계, 이미지 2/3 Samsung Galaxy A40 Charging Board Replacement: 6 단계, 이미지 3/3
    • Use Plastic tool to separate the charging board from the frame.
    • Warm the charging board slightly to make it easier to disassemble.
    • Now, install the new board and test the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
190,052 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
319 회원들
안내서 1,352개 작성하였습니다
댓글 한 개
Replaced port but phone now doesn't recognise sim can use WhatsApp though
Ann Sayer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 26
30일 전: 182
전체 시간: 4,882
