필요한 것
동영상 개요
Warm the device to soften the adhesive.
To separate the back cover, use plastic tools, a suction cup and a little ethanol alcohol.
Disconnect the battery.
Disconnect the main flex cable.
Disconnect the Coaxial antenna cables.
Remove the black Philips screw securing the motherboard to the display frame.
Use a plastic tool to remove the Motherboard.
Remove the silver Phillips screws and with a plastic tool lift up the plastic cover.
Disconnect the fingerprint sensor.
Disconnect the Main flex cable.
Remove the black screw securing the Charging board.
Use a plastic tool and gently pick up the Daughter board.
다른 3명이 해당 안내서를 완성하였습니다.
