주요 콘텐츠로 건너뛰기
Samsung Galaxy A8(2018) Back Cover Replacement
  1. Samsung Galaxy A8(2018) Back Cover Replacement, Back cover: 1 단계, 이미지 2개 중 1개 Samsung Galaxy A8(2018) Back Cover Replacement, Back cover: 1 단계, 이미지 2개 중 2개
    • Turn off your phone.
    • Prepare an iOpener or hair dryer to soften the adhesive on the back of the A8.
    • The adhesive is distributed over the outline of the back cover shown in red in the photo.
  2. Samsung Galaxy A8(2018) Back Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Use a suction cup to lift the back cover and insert an opening pick into the slot created.
    • Start in the middle and cut the adhesive while maintaining tension on the suction cup.
    • If you find it increasingly difficult to move the pick, reheat the iOpener or use a hair dryer.
  3. Samsung Galaxy A8(2018) Back Cover Replacement: 3 단계, 이미지 2개 중 1개 Samsung Galaxy A8(2018) Back Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Move your pick carefully from corner to corner. Leave a pick at each corner once it has been freed to prevent the cover from re-adhering. Repeat for all 4 corners.
    • Do not force the cover open. Re-soften the adhesive with an iOpener or hair dryer if the back cover does not come off or begins to warp.
    • On the photo opposite three corners have been released, with one corner remaining to be able to completely remove the glass.
    • Be careful not to damage the fingerprint reader connector when opening the back cover. Disconnect it following the instructions in the next step.
  4. Samsung Galaxy A8(2018) Back Cover Replacement: 4 단계, 이미지 1개 중 1개
    • Unplug the fingerprint reader with tweezers.
  5. Samsung Galaxy A8(2018) Back Cover Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the back cover.
    • Prepare for reassembly by removing the remaining adhesive from the phone with a spudger. Clean the adhesive surfaces with isopropyl alcohol and a lint-free cloth.
결론
To reassemble your device, follow the instructions in reverse order.
다른 9명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
Jerry Wheeler님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Jean pierre bourhis
회원 가입일: 03/06/18
415 평판
안내서 1개를 작성함
Leroy Merlin Leroy Merlin 회원
Community
38 회원들
안내서 249개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 70
전체 시간: 4,346
