주요 콘텐츠로 건너뛰기
Samsung Galaxy A8 (2018) Display Replacement
필요한 것
  1. Samsung Galaxy A8  (2018) Display Replacement, Display: 1 단계, 이미지 1/1
    • Before proceeding to change the screen of your Galaxy A8 (2018), press and hold the power button to turn off your device.
  2. Samsung Galaxy A8  (2018) Display Replacement: 2 단계, 이미지 1/1
    • Insert the SIM Card Ejection tool into the small hole and remove the SIM Card tray.
  3. Samsung Galaxy A8  (2018) Display Replacement: 3 단계, 이미지 1/3 Samsung Galaxy A8  (2018) Display Replacement: 3 단계, 이미지 2/3 Samsung Galaxy A8  (2018) Display Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Using a hairdryer, heat up the back of the device to loosen the adhesive.
    • Gently insert a plastic card and opening pick between the glass and frame to create an opening. Carefully separate the rear glass from the rest of the device.
    • Be careful not to overheat the rear glass since it is very fragile.
  4. Samsung Galaxy A8  (2018) Display Replacement: 4 단계, 이미지 1/2 Samsung Galaxy A8  (2018) Display Replacement: 4 단계, 이미지 2/2
    • Using a pair of tweezers, disconnect the clip connecting camera and motherboard.
    • Lift the back panel off of the chassis of the device.
  5. Samsung Galaxy A8  (2018) Display Replacement: 5 단계, 이미지 1/3 Samsung Galaxy A8  (2018) Display Replacement: 5 단계, 이미지 2/3 Samsung Galaxy A8  (2018) Display Replacement: 5 단계, 이미지 3/3
    • Use the P2 Pentalobe screwdriver to remove the 14 (0.8mm) screws.
    • Use the Phillips #0 screwdriver to remove the rest of the four 1.5mm screws.
    • Gently leverage with the spudger under the top antenna to lift it.
    • Continue with the spudger to lift and extract the NFC antenna.
  6. Samsung Galaxy A8  (2018) Display Replacement: 6 단계, 이미지 1/3 Samsung Galaxy A8  (2018) Display Replacement: 6 단계, 이미지 2/3 Samsung Galaxy A8  (2018) Display Replacement: 6 단계, 이미지 3/3
    • Disconnect the battery using the spudger.
    • Gently lift the speaker and pull it out of the slot.
    • Disconnect the display cables from the device.
  7. Samsung Galaxy A8  (2018) Display Replacement: 7 단계, 이미지 1/3 Samsung Galaxy A8  (2018) Display Replacement: 7 단계, 이미지 2/3 Samsung Galaxy A8  (2018) Display Replacement: 7 단계, 이미지 3/3
    • To soften the adhesive that binds the display panel to the chassis, heat the front panel with the hairdryer for a few seconds
    • To create an opening, insert the opening pick gently between the screen and the chassis
    • Gently slide the plastic card around the screen to take it off the chassis.
    • Be careful not to overheat the centre of the display panel as this can damage it.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Prayanshu Singla
회원 가입일: 01/22/21
428 평판
안내서 1개 작성함
York University, Team S14-G27, Melo-Thaiss Winter 2021 York University, Team S14-G27, Melo-Thaiss Winter 2021 회원
YORK-MELO-THAISS-W21S14G27
1 회원
안내서 4개 작성하였습니다
댓글 한 개
My microphone isnt working please help
alpadarkshadow - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 36
30일 전: 171
전체 시간: 7,892
