주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Samsung Galaxy Ace 수리는 저희 서비스 설명서를 사용하십시오.
  1. Samsung Galaxy Ace Teardown, Samsung Galaxy Ace Teardown: 1 단계, 이미지 1/3 Samsung Galaxy Ace Teardown, Samsung Galaxy Ace Teardown: 1 단계, 이미지 2/3 Samsung Galaxy Ace Teardown, Samsung Galaxy Ace Teardown: 1 단계, 이미지 3/3
    • Rotate your Phone.
    • Remove the plastic battery door.
    • Remove battery.
    • Unscrew all 7 screws so that the cover can be removed.
  2. Samsung Galaxy Ace Teardown: 2 단계, 이미지 1/3 Samsung Galaxy Ace Teardown: 2 단계, 이미지 2/3 Samsung Galaxy Ace Teardown: 2 단계, 이미지 3/3
    • With a plastic tool separate the frame from the aluminum plate. (either from the inside or outside)
    • Make sure your Micro SD card is removed from the device Micro SD card slot.
    • Disconnect the microphone using your fingers, be careful not to do too much pressure.
  3. Samsung Galaxy Ace Teardown: 3 단계, 이미지 1/3 Samsung Galaxy Ace Teardown: 3 단계, 이미지 2/3 Samsung Galaxy Ace Teardown: 3 단계, 이미지 3/3
    • Disconnect the light sensor and ear piece speaker.To remove this use a plastic tool.
    • Disconnect the volume rocker, be very careful! They are very thin and glued with double-sided tape. If possible, use isesamo or something really thin!
  4. Samsung Galaxy Ace Teardown: 4 단계, 이미지 1/3 Samsung Galaxy Ace Teardown: 4 단계, 이미지 2/3 Samsung Galaxy Ace Teardown: 4 단계, 이미지 3/3
    • Lift the logic board from the right side, be careful not cause any damage to gently rotate the LCD connector.
    • Now with a plastic tool you can disconnect the LCD connector.
  5. Samsung Galaxy Ace Teardown: 5 단계, 이미지 1/3 Samsung Galaxy Ace Teardown: 5 단계, 이미지 2/3 Samsung Galaxy Ace Teardown: 5 단계, 이미지 3/3
    • Remove logic board
    • Disconnect speaker and camera with a plastic tool.
  6. Samsung Galaxy Ace Teardown: 6 단계, 이미지 1/3 Samsung Galaxy Ace Teardown: 6 단계, 이미지 2/3 Samsung Galaxy Ace Teardown: 6 단계, 이미지 3/3
    • Use a plastic tool or something sharp to lift the aluminum protection that serves to fix earpiece speaker and light sensor and remove it.
    • After lifting the connector of the touch screen (black tab), lift the cable carefully!
  7. Samsung Galaxy Ace Teardown: 7 단계, 이미지 1/3 Samsung Galaxy Ace Teardown: 7 단계, 이미지 2/3 Samsung Galaxy Ace Teardown: 7 단계, 이미지 3/3
    • Press the home button to remove it. (This is not fixed,no material).
    • Heat the glass lens with a hot air gun, a tool insert after "isesamo" and slowly raise it.
    • Remove it.
  8. Samsung Galaxy Ace Teardown: 8 단계, 이미지 1/1
    • Disassembly is finished! To assemble, follow the guide from the end point to the initial.
AndreaBaglione
회원 가입일: 11/06/09
3,912 평판
안내서 3개 작성하였습니다
댓글 3개
Very helpful, I had to open it all up as shown in photo to get my stuck SIM cards out. Thanks.
Yash J - 답글
My ace s5830 cant sharging i change ic charge and battary and also can t charging why !
Jaafar Fakih - 답글
Maybe motherboard or cable is dead?
Paul Richard -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 47
전체 시간: 16,092
