주요 콘텐츠로 건너뛰기
Samsung Galaxy Alpha Back Cover Replacement
  1. Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: 1 단계, 이미지 1/3 Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: 1 단계, 이미지 2/3 Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: 1 단계, 이미지 3/3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
결론
To replace the cover, realign the cover with the device and gently press down until you hear the connections click.
다른 13명이 해당 안내서를 완성하였습니다.
Sarah
회원 가입일: 01/22/15
940 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-17, Maness Winter 2015 Cal Poly, Team 20-17, Maness Winter 2015 회원
CPSU-MANESS-W15S20G17
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 20
전체 시간: 3,762
