주요 콘텐츠로 건너뛰기
Samsung Galaxy Alpha Battery Replacement
  1. Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: 1 단계, 이미지 1/3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: 1 단계, 이미지 2/3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: 1 단계, 이미지 3/3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha Battery Replacement, Battery: 2 단계, 이미지 1/2 Samsung Galaxy Alpha Battery Replacement, Battery: 2 단계, 이미지 2/2
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Jon Brausch
회원 가입일: 01/20/15
1,542 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-17, Maness Winter 2015 Cal Poly, Team 20-17, Maness Winter 2015 회원
CPSU-MANESS-W15S20G17
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Not even a full picture of the battery agh! I need to know if I can use note 4 battery
Alex Andrei - 답글
Please also make sure that replacing the battery with a cheap knock off will disable NFC since the antenna is glued to the battery.
vargabp0 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 31
전체 시간: 4,994
