주요 콘텐츠로 건너뛰기
Samsung Galaxy Alpha microSIM Card Replacement
  1. Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: 1 단계, 이미지 1/3 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: 1 단계, 이미지 2/3 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: 1 단계, 이미지 3/3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha microSIM Card Replacement, Battery: 2 단계, 이미지 1/2 Samsung Galaxy Alpha microSIM Card Replacement, Battery: 2 단계, 이미지 2/2
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
  3. Samsung Galaxy Alpha microSIM Card Replacement, microSIM Card: 3 단계, 이미지 1/1
    • Remove your Micro SIM card from the slot shown.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 01/22/15
769 평판
안내서 1개 작성함
Cal Poly, Team 20-17, Maness Winter 2015 Cal Poly, Team 20-17, Maness Winter 2015 회원
CPSU-MANESS-W15S20G17
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 22
전체 시간: 2,408
