주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Amp 2 Home Button Replacement
필요한 것
  1. Samsung Galaxy Amp 2 Home Button Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Amp 2 Home Button Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
  2. Samsung Galaxy Amp 2 Home Button Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Amp 2 Home Button Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Amp 2 Home Button Replacement: 2 단계, 이미지 3개 중 3개
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
  3. Samsung Galaxy Amp 2 Home Button Replacement, Screen: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Amp 2 Home Button Replacement, Screen: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Amp 2 Home Button Replacement, Screen: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
    • Disconnect the connector piece from the back panel.
  4. Samsung Galaxy Amp 2 Home Button Replacement: 4 단계, 이미지 1개 중 1개
    • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
  5. Samsung Galaxy Amp 2 Home Button Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Amp 2 Home Button Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Amp 2 Home Button Replacement: 5 단계, 이미지 3개 중 3개
    • Use four plastic opening tools to gently pry off the screen.
    • Optional: Use a suction tool to pull the screen off.
  6. Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
    • Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
    • Push from the back panel to remove the bottom part of the motherboard.
    • Push from the front panel to remove the top part of the motherboard.
  7. Samsung Galaxy Amp 2 Home Button Replacement, Home Button: 7 단계, 이미지 3개 중 1개 Samsung Galaxy Amp 2 Home Button Replacement, Home Button: 7 단계, 이미지 3개 중 2개 Samsung Galaxy Amp 2 Home Button Replacement, Home Button: 7 단계, 이미지 3개 중 3개
    • Pull the black tab that is located on the bottom of the motherboard.
    • Push the home button out of the black tab.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Cory Nickolatos
회원 가입일: 07/12/18
430 평판
안내서 4개를 작성함
UW Tacoma, Team S1-G1, Cardinal Summer 2018 UW Tacoma, Team S1-G1, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G1
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 57
전체 시간: 789
