주요 콘텐츠로 건너뛰기
Samsung Galaxy Amp 2 Speaker Replacement
필요한 것
  1. Samsung Galaxy Amp 2 Speaker Replacement, Battery: 1 단계, 이미지 1/2 Samsung Galaxy Amp 2 Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
  2. Samsung Galaxy Amp 2 Speaker Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Amp 2 Speaker Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Amp 2 Speaker Replacement: 2 단계, 이미지 3/3
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
  3. Samsung Galaxy Amp 2 Speaker Replacement, Screen: 3 단계, 이미지 1/3 Samsung Galaxy Amp 2 Speaker Replacement, Screen: 3 단계, 이미지 2/3 Samsung Galaxy Amp 2 Speaker Replacement, Screen: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    $3.99
    구매
    • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
    • Disconnect the connector piece from the back panel.
  4. Samsung Galaxy Amp 2 Speaker Replacement: 4 단계, 이미지 1/1
    • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
  5. Samsung Galaxy Amp 2 Speaker Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Amp 2 Speaker Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Amp 2 Speaker Replacement: 5 단계, 이미지 3/3
    • Use four plastic opening tools to gently pry off the screen.
    • Optional: Use a suction tool to pull the screen off.
  6. Samsung Galaxy Amp 2 Speaker Replacement, Motherboard: 6 단계, 이미지 1/3 Samsung Galaxy Amp 2 Speaker Replacement, Motherboard: 6 단계, 이미지 2/3 Samsung Galaxy Amp 2 Speaker Replacement, Motherboard: 6 단계, 이미지 3/3
    • Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
    • Push from the back panel to remove the bottom part of the motherboard.
    • Push from the front panel to remove the top part of the motherboard.
  7. Samsung Galaxy Amp 2 Speaker Replacement, Speaker: 7 단계, 이미지 1/2 Samsung Galaxy Amp 2 Speaker Replacement, Speaker: 7 단계, 이미지 2/2
    • Gently pull the black piece that is connected to the top of the motherboard. This is the speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cory Nickolatos
회원 가입일: 07/12/18
415 평판
안내서 4개 작성하였습니다
UW Tacoma, Team S1-G1, Cardinal Summer 2018 UW Tacoma, Team S1-G1, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 403
