필요한 것
At the top of the device there is a small notch that is used to remove the battery door.
Using a pry tool or your fingernail, pry off the battery door from the main housing.
Place the battery door to the side.
Using a pry tool or your fingernail, pry the battery up towards you.
You have now removed the battery!
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
