주요 콘텐츠로 건너뛰기
Samsung Galaxy Attain 4G Rear Housing Replacement
필요한 것
  1. Samsung Galaxy Attain 4G Rear Housing Replacement, Placement: 1 단계, 이미지 1/1
    • Begin by turn the device over to it's back, with the screen facing down.
  2. Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Door Removal: 2 단계, 이미지 1/2 Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Door Removal: 2 단계, 이미지 2/2
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Removal: 3 단계, 이미지 1/3 Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Removal: 3 단계, 이미지 2/3 Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Removal: 3 단계, 이미지 3/3
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. Samsung Galaxy Attain 4G Rear Housing Replacement, Heads Up!: 4 단계, 이미지 1/1
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
  5. Samsung Galaxy Attain 4G Rear Housing Replacement, Screw Removal: 5 단계, 이미지 1/1
    • Remove the 6 Phillips head screws that hold the rear housing in place.
  6. Samsung Galaxy Attain 4G Rear Housing Replacement, Prying: 6 단계, 이미지 1/1
    • Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
  7. Samsung Galaxy Attain 4G Rear Housing Replacement, Remove Housing: 7 단계, 이미지 1/1
    • Lift the rear housing from the display assembly.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Josh Forester
회원 가입일: 11/28/10
2,497 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 293
