주요 콘텐츠로 건너뛰기
Samsung Galaxy Book Pro 15" Rubber Feet Replacement
필요한 것
  1. Samsung Galaxy Book Pro 15" Rubber Feet Replacement, Remove the rubber feet: 1 단계, 이미지 1/3 Samsung Galaxy Book Pro 15" Rubber Feet Replacement, Remove the rubber feet: 1 단계, 이미지 2/3 Samsung Galaxy Book Pro 15" Rubber Feet Replacement, Remove the rubber feet: 1 단계, 이미지 3/3
    • Before you begin, power down your laptop and unplug it.
    • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
    • Insert an opening pick between the rubber foot and the rear case.
    • Pry up with the opening pick to release the clips securing the foot.
    • Remove the foot.
    • Repeat this procedure for the three remaining feet.
    • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
결론
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
125,286 평판
안내서 582개 작성하였습니다
iFixit iFixit 회원
Staff
137 회원들
안내서 17,460개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 28
전체 시간: 743
