소개
When Using this Guide
Please note the circles on out pictures that indicate where screws are removed from, as most of the screw lengths are pertinent to reassembly.
필요한 것
Lift aside the casing for the battery using a plastic opening tool. This compartment is on the bottom of the camera, not under the lens.
The casing is highlighted in the red markup circle.
These steps follow completely: there is no need to reverse the order of steps to reassemble.
다른 8명이 해당 안내서를 완성하였습니다.
