주요 콘텐츠로 건너뛰기
Samsung Galaxy Camera Battery Replacement
필요한 것
  1. Samsung Galaxy Camera Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Lift aside the casing for the battery using a plastic opening tool. This compartment is on the bottom of the camera, not under the lens.
    • The casing is highlighted in the red markup circle.
  2. Samsung Galaxy Camera Battery Replacement: 2 단계, 이미지 1/1
    • The slot for the battery should look like this. This is the case for the battery.
  3. Samsung Galaxy Camera Battery Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Camera Battery Replacement: 3 단계, 이미지 2/2
    • Using plastic opening tool, slide battery capture latch back and allow battery to fall out.
    • Insert your replacement battery.
  4. Samsung Galaxy Camera Battery Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Camera Battery Replacement: 4 단계, 이미지 2/2
    • After the battery has been replaced, close the battery casing.
    • Now replace the casing from step one. Success, the battery has been replaced!
결론
These steps follow completely: there is no need to reverse the order of steps to reassemble.
다른 8명이 해당 안내서를 완성하였습니다.
Derek Brown
회원 가입일: 10/24/15
168 평판
안내서 1개 작성함
IUPUI, Team 2-3, Wilson Fall 2015 IUPUI, Team 2-3, Wilson Fall 2015 회원
IUPUI-WILSON-F15S2G3
4 회원들
안내서 4개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 21
30일 전: 75
전체 시간: 1,200
