주요 콘텐츠로 건너뛰기
Samsung Galaxy Camera Camera Flash Replacement
필요한 것
  1. Samsung Galaxy Camera Camera Flash Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Begin removing the 3/16" screws for the device.
  2. Samsung Galaxy Camera Camera Flash Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the device and remove the additional 3/16" screws.
  3. Samsung Galaxy Camera Camera Flash Replacement: 3 단계, 이미지 1개 중 1개
    • Turn the device and remove the additional 3/16" screw.
  4. Samsung Galaxy Camera Camera Flash Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Camera Camera Flash Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Camera Camera Flash Replacement: 4 단계, 이미지 3개 중 3개
    • Take the white cover plate off.
  5. Samsung Galaxy Camera Camera Flash Replacement: 5 단계, 이미지 1개 중 1개
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Samsung Galaxy Camera Camera Flash Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pull the connector away from the motherboard.
  7. Samsung Galaxy Camera Camera Flash Replacement, Lens and Motherboard: 7 단계, 이미지 1개 중 1개
    • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
  8. Samsung Galaxy Camera Camera Flash Replacement: 8 단계, 이미지 1개 중 1개
    • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
  9. Samsung Galaxy Camera Camera Flash Replacement: 9 단계, 이미지 1개 중 1개
    • Pull these connectors away from motherboard.
  10. Samsung Galaxy Camera Camera Flash Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the motherboard and lens out of the case.
  11. Samsung Galaxy Camera Camera Flash Replacement, Unscrew: 11 단계, 이미지 1개 중 1개
    • Remove all the screws circled. There is 1 1/8" screw by the flash, 1 9/32" screw that holds the flash button, 2 5/32" screw that is on the grey frame for the flash, and 2 5/32" screws that holds the cable frames on the top left.
  12. Samsung Galaxy Camera Camera Flash Replacement: 12 단계, 이미지 1개 중 1개
    • Unscrew the 3 5/32" screws that cover the battery plate.
  13. Samsung Galaxy Camera Camera Flash Replacement: 13 단계, 이미지 1개 중 1개
    • The black plates on the other side can be removed after these screws.
  14. Samsung Galaxy Camera Camera Flash Replacement: 14 단계, 이미지 1개 중 1개
    • Pull the flash and battery case out of the device.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Richard Hicks
회원 가입일: 01/13/15
1,280 평판
안내서 4개를 작성함
USF Tampa, Team 1-3, Sullivan Winter 2015 USF Tampa, Team 1-3, Sullivan Winter 2015 회원
USFT-SULLIVAN-W15S1G3
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 1,020
