주요 콘텐츠로 건너뛰기
Samsung Galaxy Camera Lens and Motherboard Replacement
필요한 것
  1. Samsung Galaxy Camera Lens and Motherboard Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Begin removing the 3/16" screws for the device.
  2. Samsung Galaxy Camera Lens and Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the device and remove the additional 3/16" screws.
  3. Samsung Galaxy Camera Lens and Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Turn the device and remove the additional 3/16" screw.
  4. Samsung Galaxy Camera Lens and Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Camera Lens and Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Camera Lens and Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Take the white cover plate off.
  5. Samsung Galaxy Camera Lens and Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Samsung Galaxy Camera Lens and Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pull the connector away from the motherboard.
  7. Samsung Galaxy Camera Lens and Motherboard Replacement, Lens and Motherboard: 7 단계, 이미지 1개 중 1개
    • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
  8. Samsung Galaxy Camera Lens and Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
  9. Samsung Galaxy Camera Lens and Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Pull these connectors away from motherboard.
  10. Samsung Galaxy Camera Lens and Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the motherboard and lens out of the case.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Richard Hicks
회원 가입일: 01/13/15
1,280 평판
안내서 4개를 작성함
USF Tampa, Team 1-3, Sullivan Winter 2015 USF Tampa, Team 1-3, Sullivan Winter 2015 회원
USFT-SULLIVAN-W15S1G3
3 회원들
안내서 4개를 작성함
1가이드 댓글
Hey mate, what do you do after the motherboard replacement? Just turn the camera on? Do you need to do a master reset?
Sam - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 21
전체 시간: 5,399
