주요 콘텐츠로 건너뛰기
Samsung Galaxy Camera Lens or Motherboard Replacement
필요한 것
  1. Samsung Galaxy Camera Lens or Motherboard Replacement, Lens or Motherboard: 1 단계, 이미지 1/1
    • Gather your camera and tools. Also make sure that the battery is removed before proceeding.
    • Follow battery replacement guide through step three to remove the battery.
  2. Samsung Galaxy Camera Lens or Motherboard Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Camera Lens or Motherboard Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Camera Lens or Motherboard Replacement: 2 단계, 이미지 3/3
    • Remove all seven 4 millimeter long screws using the PH000 screwdriver bit.
  3. Samsung Galaxy Camera Lens or Motherboard Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Camera Lens or Motherboard Replacement: 3 단계, 이미지 2/2
    • Use plastic opening tool to remove the cover on the non-lens side of the camera.
  4. Samsung Galaxy Camera Lens or Motherboard Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Camera Lens or Motherboard Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Camera Lens or Motherboard Replacement: 4 단계, 이미지 3/3
    • Open the battery compartment and remove the 2 screws. Also remove the screw from the bottom of the camera after pulling off the white sticker concealing it. Removing these screws releases the bottom of the display assembly.
    • Starting at the non-lens side of the camera, use plastic opening tool to pry screen away from main housing on all sides.
  5. Samsung Galaxy Camera Lens or Motherboard Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Camera Lens or Motherboard Replacement: 5 단계, 이미지 2/2
    • Use plastic opening tool to pull connector away from motherboard.
    • Remove screen completely and set aside.
  6. Samsung Galaxy Camera Lens or Motherboard Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Camera Lens or Motherboard Replacement: 6 단계, 이미지 2/2
    • Using the plastic opening tool, disconnect the three connectors from the motherboard.
  7. Samsung Galaxy Camera Lens or Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the three 3.5 mm long screws (red circle markers) using the PH000 screwdriver bit.
    • Remove the four 2 mm long screws (orange circle markers) using the PH000 screwdriver bit.
  8. Samsung Galaxy Camera Lens or Motherboard Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Camera Lens or Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the three 3 mm long screws connecting the lens unit to the main housing using the PH000 screwdriver bit.
    • Carefully remove the lens and motherboard from main housing.
  9. Samsung Galaxy Camera Lens or Motherboard Replacement: 9 단계, 이미지 1/3 Samsung Galaxy Camera Lens or Motherboard Replacement: 9 단계, 이미지 2/3 Samsung Galaxy Camera Lens or Motherboard Replacement: 9 단계, 이미지 3/3
    • Remove stickers off of connectors.
    • Open latch door on connectors.
    • Separate lens from motherboard.
    • Now you may replace either motherboard or lens with new part.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Keith Lipking
회원 가입일: 09/26/15
359 평판
안내서 1개 작성함
IUPUI, Team 2-3, Wilson Fall 2015 IUPUI, Team 2-3, Wilson Fall 2015 회원
IUPUI-WILSON-F15S2G3
4 회원들
안내서 4개 작성하였습니다
2 댓글
Would love a video of this, as well.
David CrossmN - 답글
Hey after you replace the motherboard do you just turn the camera on and it works?
Ive done it and some chinese characters show up in a dialog box...
Sam - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 3,158
