주요 콘텐츠로 건너뛰기
Samsung Galaxy Centura Camera Replacement
필요한 것
  1. Samsung Galaxy Centura Camera Replacement, Battery: 1 단계, 이미지 1/2 Samsung Galaxy Centura Camera Replacement, Battery: 1 단계, 이미지 2/2
    • Locate the rectangular groove on the top side of the device.
    • Firmly press the tip of your index finger, or plastic opening tool into the groove, and pull back firmly. The device should pop open as shown.
  2. Samsung Galaxy Centura Camera Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Centura Camera Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Centura Camera Replacement: 2 단계, 이미지 3/3
    • With the back casing removed, the phone should appear as shown, with a clear view of the battery.
    • Gently pull the battery up with your thumb and index finger. It should come out without resistance.
  3. Samsung Galaxy Centura Camera Replacement, Camera: 3 단계, 이미지 1/1
    • Find the positions of the seven screws on the back of the device. Use the Phillips #00 screwdriver to remove these 5.0mm screws.
  4. Samsung Galaxy Centura Camera Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Centura Camera Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Centura Camera Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Locate the three metal clips holding the camera in place, and pull these clips away from the camera using the tweezers.
    • Use the tweezers to lift the camera out of the plastic housing. It should come free without resistance.
결론
Austin Erickson
회원 가입일: 02/28/17
354 평판
안내서 3개 작성하였습니다
USF Tampa, Team S2-G5, Nance Spring 2017 USF Tampa, Team S2-G5, Nance Spring 2017 회원
USFT-NANCE-S17S2G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 251
