주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Centura Screen Replacement
필요한 것
  1. Samsung Galaxy Centura Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Centura Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Locate the rectangular groove on the top side of the device.
    • Firmly press the tip of your index finger, or plastic opening tool into the groove, and pull back firmly. The device should pop open as shown.
  2. Samsung Galaxy Centura Screen Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Centura Screen Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Centura Screen Replacement: 2 단계, 이미지 3개 중 3개
    • With the back casing removed, the phone should appear as shown, with a clear view of the battery.
    • Gently pull the battery up with your thumb and index finger. It should come out without resistance.
  3. Samsung Galaxy Centura Screen Replacement, Screen: 3 단계, 이미지 1개 중 1개
    • Find the positions of the seven screws on the back of the device. Use the Phillips #00 screwdriver to remove these 5.0mm screws.
  4. Samsung Galaxy Centura Screen Replacement: 4 단계, 이미지 2개 중 1개 Samsung Galaxy Centura Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Locate the indentation on the side of the device and gently insert the plastic opening tool into it. With a firm prying motion, the plastic should begin to come apart.
    • Gently pull apart the plastic, and set it aside. The phone should now appear as shown in the second picture.
  5. Samsung Galaxy Centura Screen Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Centura Screen Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Centura Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Pull back the clips located on the right hand side and the upper left side of the phone as shown.
    • After releasing the clips, gently raise the motherboard, exposing the screen from the back.
  6. Samsung Galaxy Centura Screen Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Centura Screen Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Centura Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Gently insert the metal spudger towards the top edge of the back side of the screen.
    • Gently apply pressure to raise the screen from its held position. Continue pulling gently upwards from one side until the screen has been completely removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Anthony Maldonado
회원 가입일: 02/28/17
134 평판
안내서 1개를 작성함
USF Tampa, Team S2-G5, Nance Spring 2017 USF Tampa, Team S2-G5, Nance Spring 2017 회원
USFT-NANCE-S17S2G5
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 55
전체 시간: 967
