주요 콘텐츠로 건너뛰기
Samsung Galaxy Centura Speaker Replacement
필요한 것
  1. Samsung Galaxy Centura Speaker Replacement, Battery: 1 단계, 이미지 1/2 Samsung Galaxy Centura Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Locate the rectangular groove on the top side of the device.
    • Firmly press the tip of your index finger, or plastic opening tool into the groove, and pull back firmly. The device should pop open as shown.
  2. Samsung Galaxy Centura Speaker Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Centura Speaker Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Centura Speaker Replacement: 2 단계, 이미지 3/3
    • With the back casing removed, the phone should appear as shown, with a clear view of the battery.
    • Gently pull the battery up with your thumb and index finger. It should come out without resistance.
  3. Samsung Galaxy Centura Speaker Replacement, External Speaker: 3 단계, 이미지 1/1
    • Find the positions of the seven screws on the back of the device. Use the Phillips #00 screwdriver to remove these 5.0mm screws.
  4. Samsung Galaxy Centura Speaker Replacement: 4 단계, 이미지 1/1
    • Gently insert the plastic opening tool into the notch on the side of the device. Apply a firm prying motion to pop open and remove the plastic casing.
  5. Samsung Galaxy Centura Speaker Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Centura Speaker Replacement: 5 단계, 이미지 2/2
    • Locate the black plastic clip at the top of the removed plastic casing. Use the metal spudger to release this clip.
    • Apply a firm prying motion to remove the pink plastic section. The external speaker is a part of this assembly.
결론
Mohsen Alshammari
회원 가입일: 02/28/17
102 평판
안내서 1개 작성함
USF Tampa, Team S2-G5, Nance Spring 2017 USF Tampa, Team S2-G5, Nance Spring 2017 회원
USFT-NANCE-S17S2G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 9
전체 시간: 256
