주요 콘텐츠로 건너뛰기
Samsung Galaxy Core Main and Front Cameras Replacement
필요한 것
동영상 개요
  1. Samsung Galaxy Core Main and Front Cameras Replacement, Vibra Motor: 1 단계, 이미지 1/2 Samsung Galaxy Core Main and Front Cameras Replacement, Vibra Motor: 1 단계, 이미지 2/2
    • Switch-off the phone.
    • Remove the Battery cover and the battery.
    • Remove an inserted SIM and Memory cards.
  2. Samsung Galaxy Core Main and Front Cameras Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Core Main and Front Cameras Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Core Main and Front Cameras Replacement: 2 단계, 이미지 3/3
    • Remove 9x Phillips screws.
    • With a plastic tool remove the Back cover.
    • The Vibrator is on the other side of the back cover
  3. Samsung Galaxy Core Main and Front Cameras Replacement, Logic Board: 3 단계, 이미지 1/3 Samsung Galaxy Core Main and Front Cameras Replacement, Logic Board: 3 단계, 이미지 2/3 Samsung Galaxy Core Main and Front Cameras Replacement, Logic Board: 3 단계, 이미지 3/3
    • Disconnect one by one:
    • Earpiece/Loudspeaker/Audio Jack connector module flex cable
    • LCD Display flex cable
    • Charging Dock/Antenna/Mic module flex cable
    • Coaxial Antenna cable
    • Carefully remove the Logic Board.
  4. Samsung Galaxy Core Main and Front Cameras Replacement, Main and Front Cameras: 4 단계, 이미지 1/3 Samsung Galaxy Core Main and Front Cameras Replacement, Main and Front Cameras: 4 단계, 이미지 2/3 Samsung Galaxy Core Main and Front Cameras Replacement, Main and Front Cameras: 4 단계, 이미지 3/3
    • Main / Rear Camera
    • Front Camera
    • With a plastic tool open the Camera flex cable connector.
    • Carefully remove the camera.
결론
다른 7명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,539개 작성하였습니다
댓글 3개
Hi, I have galaxy win and the front camera is too bad in quality, i want to replace front camera with galaxy core front camera which is very descent in compare to galaxy win. Please suggest
My email Id: shaikhyassar@gmail.com
Yassar Shaikh - 답글
اكتب عربي
Mjd Mjd - 답글
My mobile Sony m2 my camera low quality... Can I do anything for this problem??!
Mjd Mjd - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 4,493
