주요 콘텐츠로 건너뛰기
Samsung Galaxy Core Prime Home Button Replacement
필요한 것
  1. Samsung Galaxy Core Prime Home Button  Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Home Button  Replacement: 2 단계, 이미지 1/1
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Home Button  Replacement: 3 단계, 이미지 1/1
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Home Button  Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Core Prime Home Button  Replacement: 4 단계, 이미지 2/2
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Home Button  Replacement: 5 단계, 이미지 1/1
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Home Button  Replacement, Home Button: 6 단계, 이미지 1/1
    • Use your thumb to remove the sim card.
  7. Samsung Galaxy Core Prime Home Button  Replacement: 7 단계, 이미지 1/2 Samsung Galaxy Core Prime Home Button  Replacement: 7 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws that secure the midframe.
  8. Samsung Galaxy Core Prime Home Button  Replacement: 8 단계, 이미지 1/1
    • Heat the frame with a hair dryer or heat gun. Do this until the adhesive is loosened.
    • Take care when using these heating tools.
  9. Samsung Galaxy Core Prime Home Button  Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    구매
  10. Samsung Galaxy Core Prime Home Button  Replacement: 10 단계, 이미지 1/2 Samsung Galaxy Core Prime Home Button  Replacement: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect the LCD screen/touch screen ribbon from the motherboard using tweezers.
  11. Samsung Galaxy Core Prime Home Button  Replacement: 11 단계, 이미지 1/1
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    구매
  12. Samsung Galaxy Core Prime Home Button  Replacement: 12 단계, 이미지 1/1
    • Heat the sides of the screen with a heat gun or hair dryer.
  13. Samsung Galaxy Core Prime Home Button  Replacement: 13 단계, 이미지 1/1
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    구매
    • Use the iFixit Opening Tool to remove the plastic panel that separates the motherboard and the screen.
  14. Samsung Galaxy Core Prime Home Button  Replacement: 14 단계, 이미지 1/1
    • Use tweezers to remove the home button.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kate Vogel
회원 가입일: 10/02/18
187 평판
안내서 1개 작성함
Sam Houston State, Team S11-G2, Blackburne Fall 2018 Sam Houston State, Team S11-G2, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S11G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 30
전체 시간: 1,360
