소개
This guide will enable you to replace the screen in case of broken glass, failure to respond, etc. You will need a heat gun, Phillips #00 screwdriver, iFixit opening tool, and tweezers. Take care when using dangerous tools.
필요한 것
Use the Phillips #00 screwdriver to remove the eight 4 mm screws from the midframe.
이 단계에 사용된 도구:iFixit Opening Tool$1.99
Use the iFixit Opening Tool to remove the mother board.
Lift the plastic panel that separates the digitizer and the motherboard with an iFixit Opening Tool
Use a heat gun and an iFixit Opening Tool tool to separate the screen from the digitizer.
다른 7명이 해당 안내서를 완성하였습니다.
