주요 콘텐츠로 건너뛰기
Samsung Galaxy Core Prime Volume Buttons Replacement
필요한 것
  1. Samsung Galaxy Core Prime Volume Buttons Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Volume Buttons Replacement: 2 단계, 이미지 1/1
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Volume Buttons Replacement: 3 단계, 이미지 1/1
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Volume Buttons Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Core Prime Volume Buttons Replacement: 4 단계, 이미지 2/2
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Volume Buttons Replacement: 5 단계, 이미지 1/1
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Volume Buttons Replacement, Volume Button: 6 단계, 이미지 1/2 Samsung Galaxy Core Prime Volume Buttons Replacement, Volume Button: 6 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the eight 4mm screws from the midframe.
  7. Samsung Galaxy Core Prime Volume Buttons Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    iOpener
    $19.99
    구매
    • Flip the phone over (screen up). Use an iOpener to heat the frame. Do this until the adhesive is loose.
    • Use care when handling these heating tools!
  8. Samsung Galaxy Core Prime Volume Buttons Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Core Prime Volume Buttons Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    구매
    • Use an iFixit Opening Tool or a similarly shaped tool like a guitar pick to lift the mid-frame.
  9. Samsung Galaxy Core Prime Volume Buttons Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Core Prime Volume Buttons Replacement: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to unhook both of the rubber fixtures holding the volume button to the frame.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Olivia Jensen
회원 가입일: 10/02/18
664 평판
안내서 2개 작성하였습니다
Sam Houston State, Team S11-G2, Blackburne Fall 2018 Sam Houston State, Team S11-G2, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S11G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 23
전체 시간: 819
