주요 콘텐츠로 건너뛰기
Samsung Galaxy Core Screen Replacement
필요한 것
  1. Samsung Galaxy Core Screen Replacement, Screen: 1 단계, 이미지 1/3 Samsung Galaxy Core Screen Replacement, Screen: 1 단계, 이미지 2/3 Samsung Galaxy Core Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Flip the phone over and use your fingernail or an opening tool to remove the back cover.
  2. Samsung Galaxy Core Screen Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Core Screen Replacement: 2 단계, 이미지 2/2
    • Remove the battery.
    • If your phone has a SIM card or MicroSD card, remove them.
  3. Samsung Galaxy Core Screen Replacement: 3 단계, 이미지 1/1
    • Remove the 9 Phillips #00 screws from the mid-frame.
  4. Samsung Galaxy Core Screen Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Core Screen Replacement: 4 단계, 이미지 2/2
    • Use an opening pick to pry off the mid frame.
  5. Samsung Galaxy Core Screen Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Core Screen Replacement: 5 단계, 이미지 2/2
    • Disconnect the following ribbon cables from the motherboard:
    • The digitizer and LCD assembly.
    • Headphone Jack and Earpiece.
    • Daughter board flex cable.
    • Antenna connector.
  6. Samsung Galaxy Core Screen Replacement: 6 단계, 이미지 1/3 Samsung Galaxy Core Screen Replacement: 6 단계, 이미지 2/3 Samsung Galaxy Core Screen Replacement: 6 단계, 이미지 3/3
    • Use a plastic opening tool to remove the motherboard.
  7. Samsung Galaxy Core Screen Replacement: 7 단계, 이미지 1/3 Samsung Galaxy Core Screen Replacement: 7 단계, 이미지 2/3 Samsung Galaxy Core Screen Replacement: 7 단계, 이미지 3/3
    • Remove the single Phillips screw that secures the daughterboard.
    • Remove the daughterboard.
    • The flex cable is glued, so exercise extreme caution, as excessive force can damage the cable.
  8. Samsung Galaxy Core Screen Replacement: 8 단계, 이미지 1/3 Samsung Galaxy Core Screen Replacement: 8 단계, 이미지 2/3 Samsung Galaxy Core Screen Replacement: 8 단계, 이미지 3/3
    • Use an opening pick to remove the audio jack.
  9. Samsung Galaxy Core Screen Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Core Screen Replacement: 9 단계, 이미지 2/2
    • Disconnect the digitizer's ribbon cable.
  10. Samsung Galaxy Core Screen Replacement: 10 단계, 이미지 1/1
    • Push the earpiece mesh outwards to release it.
  11. Samsung Galaxy Core Screen Replacement: 11 단계, 이미지 1/1
    • Use a heat gun or an iOpener to heat the digitizer and soften the glue securing it.
    • Use an opening pick to break up the glue around the edges of the digitizer.
    • You may apply more heat if needed.
    • Remove the digitizer and any broken glass.
결론
다른 90명이 해당 안내서를 완성하였습니다.
ivan coene
회원 가입일: 03/12/14
3,006 평판
안내서 2개 작성하였습니다
댓글 11개
yes, but where can I buy the screen replacement?
Roxannie - 답글
I bought it on Ebay...
ivan coene - 답글
Comment root galaxy core prime g361f android 5.1.1
soulaemen - 답글
Follow the instructions in reverse order? Do you need glue for the new screen? What kind of glue? How is it applied?
Thomas McGuigan - 답글
Nor do they show how the new digitizer plugs in...
chris smith -
Magkano po ang magagastos lcd and touch po ung papalitan
ramil cariaga - 답글
Is the Potentially Dangerous part when you work with the glass? Just curious if there was some other hidden danger?
Sara - 답글
Jup, it's only because you work with broken glass ;)
ivan coene -
I have 2 devicies.
#1 broken LCD+digi
#2 dead with fine LCD+digi
Can I swap whole screen (LCD+digi) together with frame?
Piotr Jaremko - 답글
Never tried, but i guess you could just stop at step 9...
Let me know if it worked
ivan coene -
I own and use a core prime as my phone, it has a shattered screen, verizon wont replace it because it was a warrentty replacement for my kyocera brigadir that i dropped in the ocean, it works again btw just a bit slower, but i cant afford a new phone, and i cant deal with the glass splinters any more, i dont want to spend more then i have to, are some of these required things actually needed? Like the seperation tools, can i do the same thing with say an automotive trim tool(already have one)? It looks similar at the prying tip. Maybe a high end hair dryer instead of a heat gun? (My gf has one i can use). My true goal is to spend only the cost of the replacement parts, as i do not currently have a steady income. Thanks in advance for any advise.
S1l3ntb0b696 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 28
전체 시간: 116,947
