이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
Once the cover is removed, locate the battery that reads "SAMSUNG."
Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
Petra:
Hi I’m from Central South America and I recently got this phone for my birthday. I dropped it while at the swimming pool for my party THE SAME DAY I GOT IT and I was really sad. #sad I found your steps a-maz-ing. It helped me not only unclog the water that had corroded the battery inside, but I was able to successfully dry my phone out and replace it without too much hassle. The pictures were especially helpful because English is my fourth language. Thank you Kellie!
I am so thrilled!
-Kels
