주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Express 3 Home Button Replacement
필요한 것
  1. Samsung Galaxy Express 3 Home Button Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Home Button Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
    댓글 쓰기
  2. Samsung Galaxy Express 3 Home Button Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Express 3 Home Button Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Express 3 Home Button Replacement: 2 단계, 이미지 3개 중 3개
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
    댓글 쓰기
  3. Samsung Galaxy Express 3 Home Button Replacement, Screen: 3 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Home Button Replacement, Screen: 3 단계, 이미지 2개 중 2개
    • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
    댓글 쓰기
  4. Samsung Galaxy Express 3 Home Button Replacement: 4 단계, 이미지 1개 중 1개
    • Detach the screen connector.
    댓글 쓰기
  5. Samsung Galaxy Express 3 Home Button Replacement: 5 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Home Button Replacement: 5 단계, 이미지 2개 중 2개
    • Use a blow dryer or heating pad to heat up the screen.
    • Do not skip this step, as it may result in a broken screen and/or LCD.
    • This step loosens the glue holding the screen in place.
    댓글 쓰기
  6. Samsung Galaxy Express 3 Home Button Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Express 3 Home Button Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Express 3 Home Button Replacement: 6 단계, 이미지 3개 중 3개
    • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
    • Do this slowly and carefully, as both parts can crack very easily.
    • Ensure your tool is plastic, as a metal tool can damage the screen easily.
    댓글 쓰기
  7. Samsung Galaxy Express 3 Home Button Replacement, Back and Recent Apps Touch Sensor Button(s): 7 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Home Button Replacement, Back and Recent Apps Touch Sensor Button(s): 7 단계, 이미지 2개 중 2개
    • Use a plastic tool to remove back and/or recent tabs circuit buttons.
    • Use a plastic tool as a metal tool can be dangerous to the phone or you.
    댓글 쓰기
  8. Samsung Galaxy Express 3 Home Button Replacement, Home Button: 8 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Home Button Replacement, Home Button: 8 단계, 이미지 2개 중 2개
    • Use a #0 Phillips bit screwdriver to remove the four screws from the black, plastic piece surrounding the home button.
    • All four screws are the same size.
    댓글 쓰기
  9. Samsung Galaxy Express 3 Home Button Replacement: 9 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Home Button Replacement: 9 단계, 이미지 2개 중 2개
    • Using a sharp plastic tool such as a guitar pick or prying tool to pop up and remove the black, plastic piece.
    • Do not use a metal tool as it can be dangerous to you or the motherboard.
    댓글 쓰기
  10. Samsung Galaxy Express 3 Home Button Replacement: 10 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Home Button Replacement: 10 단계, 이미지 2개 중 2개
    • The white button will be connected to the black piece.
    • Slightly bend the black piece and gently push the white button until it pops out of the black, plastic piece.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mack Johnson
회원 가입일: 04/05/18
996 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 15
지난 30일: 49
전체 시간: 775
