이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Starting from the indent, use a finger nail or guitar pick to separate the back from the body of the phone.
Once the cover is removed you'll find the battery that reads "SAMSUNG"
Use a fingernail or a plastic tool such as a guitar pick to lift up on the bottom indent of the battery.
Use a thin plastic tool such as a guitar pick or plastic prying tool to lift out the glass digitizer and LCD screen around the edges.
Use a #0 Phillips bit screwdriver to remove the four screws from the black, plastic piece surrounding the home button.
Using a sharp plastic tool such as a guitar pick or prying tool to pop up and remove the black, plastic piece.
The white button will be connected to the black piece.
Slightly bend the black piece and gently push the white button until it pops out of the black, plastic piece.
