주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Express 3 Rear Camera Lens Replacement
필요한 것
  1. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Rear Camera Lens Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Express 3 Rear Camera Lens Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Express 3 Rear Camera Lens Replacement: 2 단계, 이미지 3개 중 3개
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Rear Camera Lens: 3 단계, 이미지 1개 중 1개
    • Carefully push a small pointed tool such as a plastic opening tool (or metal spudger if needed) underneath the camera lens in a corner.
    • Pry up each corner of the lens.
    • Be careful, especially if using the metal spudger, as if you push to hard it can cause damage to the device or yourself.
  4. Samsung Galaxy Express 3 Rear Camera Lens Replacement: 4 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Rear Camera Lens Replacement: 4 단계, 이미지 2개 중 2개
    • Slide your tool underneath one corner to the other to release the lens.
    • Make sure not to insert your tool too far as it can damage the camera.
    • When putting the new lens in make sure not to put to much force on it as it can break again.
결론
작성자
1다른 기여자 명과 함께
Mack Johnson
회원 가입일: 04/05/18
996 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 69
전체 시간: 829
