주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Express 3 Rear Camera Lens Replacement
필요한 것
    1. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Rear Camera Lens Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
      댓글 쓰기
    2. Samsung Galaxy Express 3 Rear Camera Lens Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Express 3 Rear Camera Lens Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Express 3 Rear Camera Lens Replacement: 2 단계, 이미지 3개 중 3개
      • Once the cover is removed, locate the battery that reads "SAMSUNG."
      • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
      • Do not use a metal tool, as it can cause injury.
      댓글 쓰기
    1. Samsung Galaxy Express 3 Rear Camera Lens Replacement, Rear Camera Lens: 3 단계, 이미지 1개 중 1개
      • Carefully push a small pointed tool such as a plastic opening tool (or metal spudger if needed) underneath the camera lens in a corner.
      • Pry up each corner of the lens.
      • Be careful, especially if using the metal spudger, as if you push to hard it can cause damage to the device or yourself.
      댓글 쓰기
    2. Samsung Galaxy Express 3 Rear Camera Lens Replacement: 4 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Rear Camera Lens Replacement: 4 단계, 이미지 2개 중 2개
      • Slide your tool underneath one corner to the other to release the lens.
      • Make sure not to insert your tool too far as it can damage the camera.
      • When putting the new lens in make sure not to put to much force on it as it can break again.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Mack Johnson
회원 가입일: 04/05/18
996 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 916
