이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
Once the cover is removed, locate the battery that reads "SAMSUNG."
Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 2개
My friend set on his phone the screen is broken. The phone will come on but the screen will not light up.
Same! For TWO phones now… have you had any luck on any suggestions or figuring anything out???
