주요 콘텐츠로 건너뛰기
Samsung Galaxy Fame S6812i Camera Replacement
필요한 것
  1. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery cover: 1 단계, 이미지 1/1
    • Turn the phone off and make sure your hands are clean. Use your thumb nail or a plastic spudger to pry open the back cover,
  2. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery: 2 단계, 이미지 1/1
    • Use the plastic opening tool or your thumb nail to lift the battery out of the receptacle.
  3. Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: 3 단계, 이미지 1/3 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: 3 단계, 이미지 2/3 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: 3 단계, 이미지 3/3
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
    • Make sure you remove the sticker hiding the screw on the left bottom corner.
  4. Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: 4 단계, 이미지 1/2 Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: 4 단계, 이미지 2/2
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Camera Replacement: 5 단계, 이미지 1/1
    • After separating the two frames, you will have access to the camera
  6. Samsung Galaxy Fame S6812i Camera Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Pull the camera off the system by using the tweezers. Perform this step with caution.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Charles
회원 가입일: 10/07/14
133 평판
안내서 2개 작성하였습니다
USF Tampa, Team 8-2, Leahy Fall 2014 USF Tampa, Team 8-2, Leahy Fall 2014 회원
USFT-LEAHY-F14S8G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 1,021
