주요 콘텐츠로 건너뛰기
Samsung Galaxy Fame S6812i LCD Screen Replacement
필요한 것
  1. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Battery Cover: 1 단계, 이미지 1/2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Battery Cover: 1 단계, 이미지 2/2
    • Locate the small indent in the top of the device and use your nails or the plastic opening tool to separate the cover from the mid-frame.
  2. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Battery: 2 단계, 이미지 1/2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Battery: 2 단계, 이미지 2/2
    • Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
  3. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Mid-Frame: 3 단계, 이미지 1/3 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Mid-Frame: 3 단계, 이미지 2/3 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Mid-Frame: 3 단계, 이미지 3/3
    • Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
    • One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty.
    • Use the plastic removal tool to work pry the mid-frame from the device.
    • This may take some effort, so try working around the edges slowly as to not break anything.
  4. Samsung Galaxy Fame S6812i LCD Screen Replacement, Unplug LCD Screen from the Motherboard: 4 단계, 이미지 1/3 Samsung Galaxy Fame S6812i LCD Screen Replacement, Unplug LCD Screen from the Motherboard: 4 단계, 이미지 2/3 Samsung Galaxy Fame S6812i LCD Screen Replacement, Unplug LCD Screen from the Motherboard: 4 단계, 이미지 3/3
    • Carefully use the pointed end of the spudger to disconnect the ribbon connections on the motherboard.
  5. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Motherboard: 5 단계, 이미지 1/1
    • Wedge the plastic opening tool between the motherboard and front plate to dismount the motherboard and chassis from the front plate of the phone.
  6. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove Damaged LCD Screen: 6 단계, 이미지 1/3 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove Damaged LCD Screen: 6 단계, 이미지 2/3 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove Damaged LCD Screen: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use one side of the tweezers to pry the LCD off of the front plate of the phone.
    • Work in a clean environment and do not touch the inside of the plastic screen cover or the face of the new LCD Screen. These cannot be cleaned once the device is reassembled.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Taylor
회원 가입일: 01/30/15
1,189 평판
안내서 5개 작성하였습니다
USF Tampa, Team 16-6, Watkins Winter 2015 USF Tampa, Team 16-6, Watkins Winter 2015 회원
USFT-WATKINS-W15S16G6
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 13
전체 시간: 1,937
