필요한 것
Locate the small indent in the top of the device and use your nails or the plastic opening tool to separate the cover from the mid-frame.
Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
Use the plastic removal tool to work pry the mid-frame from the device.
Carefully use the pointed end of the spudger to disconnect the ribbon connections on the motherboard.
Wedge the plastic opening tool between the motherboard and front plate to dismount the motherboard and chassis from the front plate of the phone.
Use one side of the tweezers to pry the LCD off of the front plate of the phone.
다른 7명이 해당 안내서를 완성하였습니다.
