주요 콘텐츠로 건너뛰기
Samsung Galaxy Fame S6812i Midframe Replacement
필요한 것
  1. Samsung Galaxy Fame S6812i Midframe Replacement, Remove back cover: 1 단계, 이미지 1/1
    • Start by removing the back cover by using your thumbnail to pry the cover off the midframe.
  2. Samsung Galaxy Fame S6812i Midframe Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Fame S6812i Midframe Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Fame S6812i Midframe Replacement: 2 단계, 이미지 3/3
    • Note: one of the screws is hidden under a plastic sticker.
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
  3. Samsung Galaxy Fame S6812i Midframe Replacement: 3 단계, 이미지 1/1
    • Remove the battery with plastic opening tool
  4. Samsung Galaxy Fame S6812i Midframe Replacement, Separating the midframe: 4 단계, 이미지 1/2 Samsung Galaxy Fame S6812i Midframe Replacement, Separating the midframe: 4 단계, 이미지 2/2
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Midframe Replacement, Final step: 5 단계, 이미지 1/1
    • Once you have separated the mid-frame it should look like this.
    • Replace the old mid-frame with the new one and follow the steps in reverse.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Charles
회원 가입일: 10/07/14
133 평판
안내서 2개 작성하였습니다
USF Tampa, Team 8-2, Leahy Fall 2014 USF Tampa, Team 8-2, Leahy Fall 2014 회원
USFT-LEAHY-F14S8G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 592
