필요한 것
Start by removing the back cover by using your thumbnail to pry the cover off the midframe.
Using the plastic opening tool pry into the bezel to remove the mid-frame
Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
Once you have separated the mid-frame it should look like this.
Replace the old mid-frame with the new one and follow the steps in reverse.
다른 한 분이 해당 안내서를 완성하였습니다.
