주요 콘텐츠로 건너뛰기
Samsung Galaxy Fame S6812i Motherboard Replacement
필요한 것
  1. Samsung Galaxy Fame S6812i Motherboard Replacement, Remove Battery Cover: 1 단계, 이미지 1/2 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove Battery Cover: 1 단계, 이미지 2/2
    • Locate the small indent in the top of the device and use your nails or a spudger to separate the cover from the mid-frame.
  2. Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Battery: 2 단계, 이미지 1/2 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Battery: 2 단계, 이미지 2/2
    • Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
  3. Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Mid-Frame: 3 단계, 이미지 1/3 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Mid-Frame: 3 단계, 이미지 2/3 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Mid-Frame: 3 단계, 이미지 3/3
    • Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
    • One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty.
    • Use the plastic removal tool to work pry the mid-frame from the device.
    • This may take some effort, so try working around the edges slowly as to not break anything.
  4. Samsung Galaxy Fame S6812i Motherboard Replacement, Unplug LCD Screen from Motherboard: 4 단계, 이미지 1/3 Samsung Galaxy Fame S6812i Motherboard Replacement, Unplug LCD Screen from Motherboard: 4 단계, 이미지 2/3 Samsung Galaxy Fame S6812i Motherboard Replacement, Unplug LCD Screen from Motherboard: 4 단계, 이미지 3/3
    • Locate the two ribbon cable connections on the motherboard. GENTLY use the pointed end of the spudger to disconnect the cables. Lift the motherboard out of the phone.
  5. Samsung Galaxy Fame S6812i Motherboard Replacement: 5 단계, 이미지 1/1
    • Using your fingers or a plastic opening tool, carefully lift the motherboard assembly from the phone.
  6. Samsung Galaxy Fame S6812i Motherboard Replacement, Chassis Removal: 6 단계, 이미지 1/2 Samsung Galaxy Fame S6812i Motherboard Replacement, Chassis Removal: 6 단계, 이미지 2/2
    • On the front face of the motherboard, locate the two #00 Phillips head screws. These hold the SIM card chassis in place.
    • Keep these screws separate from the back plate screws.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Taylor
회원 가입일: 01/30/15
1,189 평판
안내서 5개 작성하였습니다
USF Tampa, Team 16-6, Watkins Winter 2015 USF Tampa, Team 16-6, Watkins Winter 2015 회원
USFT-WATKINS-W15S16G6
2 회원들
안내서 5개 작성하였습니다
댓글 한 개
How to jumper network problem
Kshitiz khadka - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 1,211
