주요 콘텐츠로 건너뛰기
Samsung Galaxy Fame S6812i Vibration Unit Replacement
필요한 것
  1. Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Backplate: 1 단계, 이미지 1/2 Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Backplate: 1 단계, 이미지 2/2
    • Locate the small indent in the top of the device and use your nails or a spudger to separate the backplate from the mid-frame.
  2. Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Battery: 2 단계, 이미지 1/2 Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Battery: 2 단계, 이미지 2/2
    • Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
  3. Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Mid-Frame: 3 단계, 이미지 1/3 Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Mid-Frame: 3 단계, 이미지 2/3 Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Mid-Frame: 3 단계, 이미지 3/3
    • Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
    • One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty.
    • Use the plastic removal tool to work pry the mid-frame from the device.
    • This may take some effort, so try working around the edges slowly as to not break anything.
  4. Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove Damaged Vibration Unit: 4 단계, 이미지 1/2 Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove Damaged Vibration Unit: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • The vibration unit can be found on the internal side of the mid-frame, in the upper left corner.
    • Using the tweezers, remove the small plastic slip to the left of the unit. The optimal place to grab this is on the small flap on the slip's right.
    • Place the head of the tweezers in the small crevice on the bottom left of the device's housing and push up from under it. This will pop out the vibration unit.
    • These parts are held in via a weak adhesive; some amount of force may be required.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Taylor
회원 가입일: 01/30/15
1,189 평판
안내서 5개 작성하였습니다
USF Tampa, Team 16-6, Watkins Winter 2015 USF Tampa, Team 16-6, Watkins Winter 2015 회원
USFT-WATKINS-W15S16G6
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 329
